Autor Tema: Yamaha 2009 Royal Star Venture  (Posjeta: 3296 )
« : Studeni 26, 2008, 21:25:10 pm »
ngine
Type   79-cubic-inch (1294cc) liquid-cooled 70° V-four; DOHC, 4 valves/cylinder
Bore x Stroke   79mm x 66mm
Compression Ratio   10.0:1
Carburetion   (4) 32mm Mikuni CV
Ignition   TCI: Transistor Controlled Ignition
Transmission   5-speed, wide-ratio w/5th-gear overdrive; hydraulic clutch
Final Drive   Shaft
Chassis
Suspension/Front   Telescopic fork; air-assist, 5.5-in travel
Suspension/Rear   Single shock; air-assist, 4.1-in travel
Brakes/Front   Dual hydraulic disc, 298mm
Brakes/Rear   Hydraulic disc, 320mm
Tires/Front   150/80-16
Tires/Rear   150/90-15
Wheels   7-spoke cast
Dimensions
Length   104.5 in
Width   35.4 in
Height   61.6 in
Seat Height   29.5 in
Wheelbase   67.1 in
Fuel Capacity   6.0 gal
Fuel Economy**   42 mpg
Wet Weight   869 lb
Other
Warranty   5 Year (Limited Factory Warranty)
Offline lopac
  • zaprešić
  • Postova: 300
  • jinlun 250
Odg: Yamaha 2009 Royal Star Venture
« Odgovori #1 : Studeni 26, 2008, 21:38:13 pm »
otkad ja imam muziku u crvenom koferu i to na uesbe a ne na demode čejndžere :icon_fU:
tko izgubi dobitak,dobije gubitak
« Odgovori #2 : Studeni 26, 2008, 23:33:18 pm »
 my tipe  :icon_super:
 ne vidim podatke o okr. momentu i snazi ... ali siguran sam da je dovoljan  :icon_mrgreen:
« Odgovori #3 : Studeni 28, 2008, 10:07:03 am »
predivno....ali malo čudan podatak za gume Tires/Front   150/80-16
« Odgovori #4 : Studeni 28, 2008, 11:05:40 am »
ovo mi je već dosta interesantnije od Kawca. Taj V4 ima jako dobar renome. Konačno su i Japanci došli k pameti i vraćaju na tržište dokazane vrijednosti.
« Odgovori #5 : Studeni 28, 2008, 11:24:34 am »
Opaa,znao sam da u tebi čuči jedan ortodoksni yamaholjubac :@:
« Odgovori #6 : Studeni 28, 2008, 11:25:21 am »
cijena u us je cca 18 500 $ iliti 102.305,00 kn
sto nije pretjerano visoko
vjerovatno bi kod nas na cestu dosao cca 180 000  :dontknow:
« Odgovori #7 : Studeni 28, 2008, 14:29:48 pm »
ne. nego ih ima previše oko mene  :icon_rolleyes:
 :icon_mrgreen:
« Odgovori #8 : Studeni 29, 2008, 00:53:16 am »
V4 fora koncept
Al mi je motor PREVELIK jednostavno je krava
« Odgovori #9 : Studeni 29, 2008, 10:26:54 am »
prevelko za sta?
pogledaj filmic
Goldwing at Dragon Tail
[youtube]http://www.youtube.com/watch?v=kFleFrJx7nw[/youtube]
The Tail of the Dragon at Deals Gap, with 318 curves in 11 miles
« Odgovori #10 : Prosinac 05, 2008, 09:00:22 am »
O ma vidio sam to, al svejedno prevelik
« Odgovori #11 : Prosinac 05, 2008, 09:37:03 am »
ma kuzim te
i meni je to malo previiše
« Odgovori #12 : Prosinac 06, 2008, 09:09:17 am »
Takvi motori su fora, ali mene odmah asociraju na nešto ovakvo....
« Odgovori #13 : Prosinac 06, 2008, 10:24:44 am »
Ova kučica na kotačima je :icon_super:  ali mislim da kod nas ne bi prošla homologizaciju :llllol: :llllol: :llllol:
Offline lopac
  • zaprešić
  • Postova: 300
  • jinlun 250
« Odgovori #14 : Prosinac 17, 2008, 02:13:46 am »
kad su naše ceste ljepše pa mora bit i skuplje :icon_fU:
