Autor Tema: Honda  (Posjeta: 15580 )
Honda
« : Rujan 07, 2008, 13:53:41 pm »
2008 - 31   38
0859/08   Germany
Category: Motor vehicles
Product: Motorcycles - Fireblade
Brand: HONDA
Type/number of model: CBR1000RR8, type SC59
Description: Vehicles from the model year 2008 with following VINs are affected:
- JH2SC59A*8K020002 to JH2SC59A*8K020662
- JH2SC59A*8M000038 to JH2SC59A*8M013195
- JH2SC59B*8K020001 to JH2SC59B*8K020088
- JH2SC59B*8M000002 to JH2SC59B*8M001687
Country of origin: Germany
No picture available
Burns
The product poses a risk of burns because strong vibrations intensified by high engine speed may cause the coolant hose clamp fitted to the water pump nozzle to break, allowing hot coolant to leak onto the rider's left foot, which, in the worst case, may lead to scalding.
Voluntary corrective action taken by the manufacturer.
Odg: Honda
« Odgovori #1 : Rujan 07, 2008, 13:55:23 pm »
2008 - 24   23
0655/08   Portugal
Product: Motorcycle
Brand: HONDA
1) PS 125i – PS 150i (de 2006 e 2007); 2) SH 125i – SH 150i (de 2005, 2006 e 2007).
Description: Various VINs (see lists attached)
Country of origin: Italy
No picture, no test report.
Fire
The product poses a risk of fire because if the terminal and wire are incorrectly inserted in the ACG stator plug, the resistance of the contact in the terminal exceeds the standard value necessary, generating heat in the connection and resulting in the separation of the two parts. Once separation occurs, the generation of heat accelerates, melting the plug, which causes the motor to stop or the vehicle to catch fire.
Voluntary corrective action taken by the importer.
Odg: Honda
« Odgovori #2 : Rujan 07, 2008, 13:55:56 pm »
2008 - 24   25
0657/08   Portugal
Category: Motor Vehicles
Product: Motorcycles Honda TRX
Brand: HONDA Type/number of model: TRX 500 FE / FM / FA (2007)
Country of origin: United States
Injuries
These products pose a risk of injuries due to :
- water (from rain or washing) entering the wiring from the right-hand side of the motor’s stop button, which accumulates inside the plastic cladding. The accumulated water can leak into the wires and seep into the accelerator’s position sensor. In cold climates, the water in the accelerator’s position sensor can freeze, thereby preventing the motor from decelerating after the accelerator has been released.
- corrosion and the resulting increase in resistance between the resistor and the terminal of the accelerator’s position sensor may cause the ECU to detect a fault in the accelerator’s position sensor. This may cause the indicator lights to activate or to fail to change in certain models.
Voluntary corrective actions taken by the importer.
Odg: Honda
« Odgovori #3 : Rujan 07, 2008, 13:56:24 pm »
2008 - 20   16
0561/08   Spain
Brand: HONDA
-CBF500 2006 from Italy, 500 cc motorcycle
-CBF600 2006 from Italy, 600 cc motorcycle
-VT750C 2007 from Japan, 750 cc motorcycle
-VTX1300 2007 from the USA, 1300 cc motorcycle
Description: The affected units are:
- CBF500 2006: Units with chassis numbers from:
ZDCPC39C*6F035401 to ZDCPC39C*6F038940 and from
ZDCPC39A*6F035701 to ZDCPC39A*6F038700 ;
type number of approval e3*2002/24*0244
- CBF600 2006: Units with chassis numbers from:
ZDCPC38E*6F090629 to ZDCPC38E*6F092908,
from ZDCPC38F*6F090749 to ZDCPC38F*6F093028,
from ZDCPC38A*6F090509 to ZDCPC38A*6F093388
and from ZDCPC38B*6F089789 to ZDCPC38B*6F093208; type number of approval e3*2002/24*0231
- VT750C 2007: Units with chassis numbers from:
JH2RC50A*7K310001 to JH2RC50A*7K310484,
from JH2RC50A*7M301101 to JH2RC50A*7M301497
and from JH2RC50A*7M320001 to JH2RC50A*7M320360;
type number of approval e3*2002/24*0239
- VTX1300 2007: Units with chassis numbers from:
1HFSC52A*7A400221 to 1HFSC52A*7A401210 type number of approval e4*92/61*0152.
Country of origin: Japan, Italy and United States
Fire
The product poses a risk of fire because, due to a production problem in the fuel control valve diaphragm, the diaphragm may become permeable, allowing petrol to leak out. This could cause petrol leakage through the vent of the diaphragm, constituting a fire hazard.
Odg: Honda
« Odgovori #4 : Rujan 07, 2008, 13:56:56 pm »
2008 - 2   2
0008/08   Greece
Product: Motorcycles - Fuel tank air vent pipe
Brand: HONDA
Type/number of model: Motorcycles, model CBR1000, model code SC57.
Description: The recall concerns certain 2006 and 2007 model year CBR1000RR units. Various VIN.
Fire
The product poses a risk of fire because the air vent pipe in the fuel tank resonates at a specific engine rotation speed and in some cases this may cause the air vent pipe to crack in the brazed portion of the air vent pipe in the bottom of the fuel tank. Construction of the fuel tank makes two different brazing methods for the air vent pipe, MIG brazing and flame brazing.
Only MIG brazed fuel tanks encounter high stress generated at the brazed area of the air vent pipe due to the shape of the brazing and cracking may occur due to fatigue, resulting in fuel leakage.
Odg: Honda
« Odgovori #5 : Rujan 07, 2008, 13:57:30 pm »
2007 - 21   4
0476/07   Portugal
Product: Motorbike Honda NVS50 Today
Brand: Honda
Type/number of model: NVS 50 Today.
VINs:
LALAF61A*3000023 – LALAF61A*3003988,
LALAF611*0000000 – LALAF611*9999999,
AF61-1095014 – AF61-1299103
Description: NVS 50 Today 2004 and 2006 model year
Country of origin: China
Injuries
This product poses a serious risk of injuries because the speedometer cable on the units affected may break and prevent the speedometer displaying the speed. Inspection of a speedometer cable and a brake panel revealed a split in the outer lining material (PVC), with corrosion of the winding of the outer structure and the inner winding at the area of the split, causing the speedometer reel to seize up and break. Reproduction tests revealed that certain components of the grease applied to the sliding surface of the inner cable caused hardening of the outer lining material, which might then split. If water enters through the split, the winding of the outer body and the inner cable corrode and seize up. The speedometer then breaks down when the speedometer reel or inner cable break.
Voluntary recall from consumers and corrective actions taken by the importer
Odg: Honda
« Odgovori #6 : Rujan 07, 2008, 13:57:57 pm »
2007 - 10   10
0249/07   Portugal
Product: Motorcycle
Brand: HONDA
Type/number of model: TRX 450 R/ER.
Chassis numbers:
(JH2TE320*6K000019 – JH2TE320*6K010997
JH2TE322*6K000001 – JH2TE322*6K000442
JH2TE32U*6K000001 – JH2TE32U*6K000211
JH2TE324*6K000007 – JH2TE324*6K000111
JH2TE32U*6K000212 – JH2TE32U*6K000227)
Injuries
Some vehicles may present a safety defect in the steering system. The knees of the front suspension arms, both lower and upper (from the left and from the right) may have been affected during the production process, resulting in rapid wear and possible separation of the knees. If they come apart when the vehicle is in motion, control of the steering may be lost, causing an accident.
Odg: Honda
« Odgovori #7 : Rujan 07, 2008, 13:58:53 pm »
2007 - 2   19
0049/07   Spain
Product: Motorcycle
Brand: HONDA
Type/number of model: Model: SCV100 LEAD,
internal code: JF11.
Scooter type motorcycle, 100 cc.
Affected vehicles have chassis numbers from ME4JF11A* 58009186 to ME4JF11A* 58028245.
Country of origin: India
Injury
The product poses a risk of injury because the nuts of the wheel hub may be insufficiently tightened, which could cause instability of the vehicle when ridden.
Odg: Honda
« Odgovori #8 : Studeni 15, 2008, 22:22:05 pm »
2008 - 45      2
1306/08    Portugal
Brand: Honda
Type/number of model: NT 700 V/VA
Description: Honda Motorcycles, model ‘NT 700 V/VA (2008)’ with the following vehicle identification numbers (VINs):
VTMRC52A*8E020001
– VTMRC52A*8E020360.
VTMRC52U*8E000001
– VTMRC52U*8E000060.
VTMRC52B*8E020005
– VTMRC52B*8E022884.
Country of origin: Spain
   Injuries
The product poses a risk of injuries because one of the two screws used to mount the bank angle sensor may not be sufficiently tight. If the sensor becomes loose, the engine may cut out.
Odg: Honda
« Odgovori #9 : Studeni 22, 2008, 08:41:03 am »
2008 - 46      5
1323/08    Portugal
Product: Motorcycle - Honda CB 1000
Brand: Honda
Type/number of model: CB 1000 R/RA.
Description: Honda motorcycles, CB 1000 R/RA (2009) models with the following VINs:
ZDCSC60A*9F000074 - *9F008647
ZDCSC60B*9F000074 - *9F008647
ZDCSC60C*9F000074 - *9F008647
ZDCSC60D*9F000074 - *9F008647
   Injuries
The product poses a risk of injuries because part of the rear light may not function, causing the level of light emitted to fall below the approved standard, thus posing the risk of an accident.
Odg: Honda
« Odgovori #10 : Veljača 01, 2009, 20:29:08 pm »
2009 - 3      1
0087/09    Portugal
Product: Honda motorcycles
Brand: Honda
Type/number of model: CRF 150 R/RB (2007 and 2008)
Description: Honda brand motorcycles: - model ‘CRF 150 R (normal wheel)’ and VIN: JH2KE03A*7K000002 – JH2KE03A*7K000579 // JH2KE03A*8K100001 – JH2KE03A*8K100003;
- model ‘CRF 150 RB (big wheel)’ and VIN: JH2KE03B*7K000001 – JH2KE03B*7K001632 // JH2KE03B*8K100001 – JH2KE03B*8K100418.
   Injuries
The product poses a risk of injuries due to a possible anomaly in the welding on the right-hand side of the swing arm. In certain driving conditions, the welding may fail and the swing arm could break, causing an accident in which the rider may be seriously injured.
   Voluntary corrective actions taken by the manufacturer.
Odg: Honda
« Odgovori #11 : Travanj 13, 2009, 23:46:37 pm »
2009 - 13      21
0479/09    Portugal
Brand: Honda
Type/number of model: “CBF600N08”, “CBF600NA08”, “CBF600S08” and “CBF600SA08”, from 2008, produced by “Honda Italia Industriale”.
Description: “Honda” motorcycles, with model numbers and VIN as follows:
1- model “CBF600N08”: - ZDCPC43E08F001479 / ZDCPC43E08F014308; - ZDCPC43E08F001839 / ZDCPC43E08F015597; - ZDCPC43E08F001109 / ZDCPC43E08F013558.
2- model “CBF600NA08”: - ZDCPC43H08F002269 / ZDCPC43H08F014788; - ZDCPC43F08F001895 / ZDCPC43F08F017938; - ZDCPC43F08F001119 / ZDCPC43F08F011851. — “CBF600S08”: - ZDCPC43A08F000769 / ZDCPC43A08F017878.
3- “CBF600SA08”: - ZDCPC43D08F000479 / ZDCPC43D08F017098; - ZDCPC43B08F000419 / ZDCPC43B08F018178; - ZDCPC43B08F000119 / ZDCPC43B08F018022; - ZDCPC43B08F000899 / ZDCPC43B08F018118.
   Injuries
The product poses a risk of injuries because the speedometer may display incorrect information. Water may get into the wiring and build up in the U-shaped protection tube for the ground wire. This could trigger a short-circuit in the terminal of the VSS (vehicle speed sensor) and, consequently, cause the speedometer to fail.
Odg: Honda
« Odgovori #12 : Studeni 07, 2009, 11:10:32 am »
2009 - 43      45
1447/09    Germany
Product: Motorcycle - Honda VTX1800C2
Brand: Honda
Type/number of model: Model VTX1800C2, type SC46, EC type approval e2*92/61*0107*00
Description: The vehicles concerned were built in 2002 and have the following vehicle identification numbers:
1HFSC46A*2A001270 – 1HFSC46A*2A001489
1HFSC46A*2A001490 – 1HFSC46A*2A001549.
No pictures available
   Injuries
The product poses a risk of injuries because the weld seam on the left-hand side of the swing arm may be incorrectly positioned which could cause the swing arm to break while the motorcycle is being ridden and thus cause an accident.
Odg: Honda
« Odgovori #13 : Studeni 24, 2009, 23:46:39 pm »
2009 - 45      1
1484/09    Portugal
Product: Motorcycle - Honda CB600F / CBF600 / CB1000R
Brand: Honda
- CBF600 (2008 model); ZDCPC41A*8F064104 – ZDCPC41A*8F164163 // ZDCPC41A*8F064827 – ZDCPC41A*8F064845;
- CBF600 (2009 model): ZDCPC41A*9F076887 – ZDCPC41A*9F077126 // ZDCPC41A*8F077337 – ZDCPC41A*8F077415;
- CBF600 (2009 model): ZDCPC43B09F032857 and ZDCPC43B09F032859;
– CB1000R (2009 model): ZDCSC60A*9F004614 – ZDCSC60A*9F004807 // ZDCSC60A*9F002348 – ZDCSC60A*9F002380.
Full list of VINspdf is attached.
http://ec.europa.eu/consumers/images/rapex/2009-w45/2009-w45_1-1.pdf
Description: Motorcycle
No picure available
   Injuries
The product poses a risk of injuries because the mounting bolts on the rear brake master cylinder may not be properly tightened and could possibly come loose during use affecting the operation of the rear brake.
Odg: Honda
« Odgovori #14 : Veljača 20, 2010, 22:37:54 pm »
2010 - 7      9
0240/10    Germany
Product: Motorcycle - Honda VT750
Brand: Honda
Type/number of model: Model VT750, Type RC50 and RC53, ECG type approvals e4*2002/24*1355*00 and e4*2002/24*0239*01
Description: Motor vehicles affected are from model years 2007-2009, within the VIN ranges:
JH2RC50B*8M400002 – JH2RC50B*8M400254
JH2RC50B*8K410001 – JH2RC50B*8K420609
JH2RC50B*9K500001 – JH2RC50B*9K501737
JH2RC53A*7M000001 – JH2RC53A*7M003720
JH2RC53A*8M100001 – JH2RC53A*8M100160
JH2RC53A*8K110001 – JH2RC53A*8K121422.
   Fire
The product poses a risk of injuries because, due to incorrect positioning of the battery positive cable the battery cable coating may become worn through. This could cause a short circuit of the battery cable, resulting, in the worst case scenario, in fire.
