Autor Tema: HONDA RUNE HRVATSKA  (Posjeta: 4981 )
Offline zuti
  • Zabok
  • Postova: 506
  • Aprilia rsv 1000 mille
HONDA RUNE HRVATSKA
« : Veljača 27, 2008, 15:53:47 pm »
Obavjest honde rune 1800 stigle u HR. Cijena prava sitnica 289.990,00kn, požurite i kupite dok ima još malo pa nestalo. :icon_super: :icon_super:
Odg: HONDA RUNE HRVATSKA
« Odgovori #1 : Veljača 27, 2008, 15:57:24 pm »
Zanimljivo.....al imam samo jednu malu opasku na design...... :puke:
« Odgovori #2 : Veljača 27, 2008, 16:00:00 pm »
pa nebi za taj motor dal tolku paru nit da sam sto puta :motocikli006:
« Odgovori #3 : Veljača 27, 2008, 16:37:58 pm »
Pa da je cijena i 350000kn prodat ce se par komada sigurno...
bart
« Odgovori #4 : Veljača 27, 2008, 17:44:56 pm »
Za te novce može se kupiti goldwing za putovanje, cbr 1000 za hvatat komade i još ti ostane za kineski skuter za po gradu
« Odgovori #5 : Veljača 27, 2008, 18:24:20 pm »
rekli bo onda neki
"i onda je HD skup"
« Odgovori #6 : Veljača 27, 2008, 18:36:26 pm »
Koja je to mašina,dajte neke specifikacije
Zašto košta toliko ?
« Odgovori #7 : Veljača 27, 2008, 19:12:03 pm »
Engine Type: 1832cc liquid-cooled horizontally opposed six-cylinder-(97 hp)
Bore and Stroke: 74.0mm x 71.0mm
Compression Ratio: 9.8:1
Valve Train: SOHC; two valves per cylinder
Carburetion: PGM-FI with automatic choke
Ignition: Computer-controlled digital with three-dimensional mapping
Honda Valkyrie Rune Drive Train:
Transmission: Five-speed
Final Drive: Shaft
Honda Valkyrie Rune Suspension:
Front Suspension: Trailing bottom link; 3.9-inch travel
Rear Suspension: Unit Pro-Link with single shock; 3.9-inch travel
Honda Valkyrie Rune Brakes:
Front Brakes: Dual full-floating 330mm discs with three-piston caliper
Rear Brake: Single 336mm disc with two-piston caliper
Front Tire: 150/60R-18 radial
Rear Tire: 180/55R-17 radial
Honda Valkyrie Rune Dimensions:
Rake: 0 degrees
Trail: NA
Wheelbase: 68.9 inches
Seat Height: 27.2 inches
Dry Weight: 794 pounds
Fuel Capacity: 6.1 gallons
« Odgovori #8 : Veljača 27, 2008, 19:28:33 pm »
Offline zuti
  • Zabok
  • Postova: 506
« Odgovori #9 : Veljača 27, 2008, 20:03:01 pm »
Za sve one koji neznaju o kakvom se motoru radi neka pogledaju filmić, po meni motor vrijedi svaku lipu jer je to motor koji je bez konkurencije i potpuno jedinstven. :icon_smile:
[youtube]pgrg9hdXPB4[/youtube]
« Odgovori #10 : Veljača 27, 2008, 20:16:53 pm »
 Mislim da sam negdje pročitao da je to ustvari agregat od Goldwinga  :dontknow:
 Izgleda premočno  :icon_thumright: ali neznam šta i koliko bih morao posjedovat da bih se odličio toliko novčića utuči u 2 kotača  :icon_scratch:
Offline zuti
  • Zabok
  • Postova: 506
« Odgovori #11 : Veljača 27, 2008, 20:22:56 pm »
Kučerinu, apartmane na moru, penthouse u centru zagreba, ferrari, s klasu, bmw x5 i jos puno puno toga, ili jednostavno biti lud ko šiba i imati odličan prosjek plače, kaj se mene tiče lud ko šiba jesam još mi samo fali 25t kuna prosjek plače. :icon_mrgreen: :icon_mrgreen:
« Odgovori #12 : Veljača 27, 2008, 20:43:42 pm »
Ma ne treba ti samo biti Paris Hilton majka ili sastra da te nauči kako se živi  :icon_fU: :icon_fU:
« Odgovori #13 : Veljača 27, 2008, 20:59:45 pm »
Honda Valkyra je Golwing prošla generacija prerađen u cruisera po uzoru na američki stil motora. Boxer 6 cilindara 1500 ccm. Sa izlaskom novog modela Winga od 1800 ccm, također su išli na izradu ogoljenog cruisera, ali, hvala bogu, ovaj put se išlo i na originalni, posebno rađen design za taj model. Na početku se spominjalo ime "Valkyra 2" kao oznaku nove generacije tog modela motora. Kad je izašao u prodaju, nazvan je Rune, a mogao se vidjeti i naziv Valkyra Rune. Ovu smo vidjeli u Padovi iste godine kad je izašao taj model. S obzirom na svoju veličinu, design je fenomenalan i nije mogao biti bolje napravlje. motor je ogroman, Triumph Rocket je sitan u usporedbi s Runeom, i samo je Boss Hoss impozantniji, ali to ionako nije normalan motor.
[privitak je izbrisao admin]
« Odgovori #14 : Veljača 27, 2008, 21:25:19 pm »
  Bravo James  :icon_thumright: čitao sam o Valkyra Rune, ali nisam bio siguran jel to isti stroj.
  Nije ni pamčenje više što je bilo nekad  :icon_mrgreen: malo me muči zub vremena  :icon_redface:
