Autor Tema: Neander Custom TDi  (Posjeta: 5429 )
Offline baron0101
  • Postova: 364
Neander Custom TDi
« : Kolovoz 06, 2007, 12:49:29 pm »
Neander Custom TDi
Iako nije prvi motocikl s dizelskim agregatom, Neander se može pohvaliti time sto je postigao dobre podajne rezultate
Cijena je 70.000 Eura
SPECIFICATIONS
Engine: Air/oil-cooled turbocharged parallel-twin diesel with twin 360-degree geared crankshafts, dual con-rods per cylinder
Valve arrangement: Apfelbeck eight-valve cylinder head with gear-driven double overhead camshafts, and radial valves with opposed inlet and exhaust tracts
Bore x stroke, displacement: 108 x 78.2 mm, 1430cc
Compression ratio: 16:1
Carburetion: Garrett turbocharger with intercooler, Bosch electronic direct fuel injection, single top injector, 31mm throttle body
Transmission: 6-speed Aprilia RSV1000R gearbox, multiplate dry clutch
Final drive: Belt
Weight: 595 lbs. dry
Rake/trail: 31 degrees / 109 mm
Wheelbase: 68.5 in.
Seat height: 25.5 in.
Front suspension: 43mm Paioli inverted fork
Rear suspension: Single cantilever Ohlins damper
Wheels: Spun-aluminum, 18x3.5 front, 18x5.5 rear
Front brake: 2, 4-piston Performance Machine calipers, 11.8-in. discs
Rear brake: 4-piston Performance Machine caliper, 11.8-in. disc
Front tire: 130/60-18 Metzeler Marathon
Rear tire: 240/40-18 Metzeler Marathon
Claimed top speed: Over 140 mph Claimed power & torque (at crankshaft): 94 bhp @ 4200 rpm, 129 ft/lb @ 2600 rpm
Agregat krasi Garettov turbo punjač, Bosch - sustav ubrizgavanja, mijenjač preuzet s Aprilinog top modela RSV 1000...
Za završni prijenos se koristi remen.
2t u srcu
Offline toldi
  • Postova: 903
  • Aprilia Pegaso
    • Vanishing-Points
Odg: Neander Custom TDi
« Odgovori #1 : Kolovoz 06, 2007, 13:29:25 pm »
Ne kužim čemu dve klipnjače za jedan klip da ga jebeš... :icon_scratch:
Eventualno za vibracije brijem ali...
Ali motor dobro djeluje samo cjena je ono... :dontknow:
http://WWW.VANISHING-POINTS.COM
Ride long and prosper!
Offline baron0101
  • Postova: 364
« Odgovori #2 : Kolovoz 06, 2007, 13:33:24 pm »
Ne kužim čemu dve klipnjače za jedan klip da ga hebeš... :icon_scratch:
Točno!!
Vrte se kontra jedna od druge te uveliko smanjuje vibracije...
2t u srcu
« Odgovori #3 : Kolovoz 06, 2007, 14:10:16 pm »
Evo malo C/P iz jedne druge teme
Neander, uspio sam naći na netu.
Ovo je s početka projekta
sad je ovakav
1400ccm, 100ks, turbodiesel, preko 70000eur :icon_eek:
Nisam mislio da ću to ikad reći, ali sviđa mi se motor
Dopao mi se taj motor na prvi pogled, a mislio sam da nikad diesel neće biti motocikl. sa svim ovim normama, zakonima i cijenama, mogao bi jako skočiti interes za ovakve motore pa će možda s vremenom biti isplativija masovna proizvodnja s realnijim cijenama. Tako da ćemo pod stare dane možda i njega računati za opciju ako se bude nešto kupovalo.
Doduše, nikad motor ovakvih karakteristika neće biti jeftin, ali ako se spusti u rang Harleya,  mogao bi imati dosta kupaca. mislim da kvaliteta neće biti upitna, na slikama izgleda uredno, a presjek agregata mi daje dojam  da se na projektu radilo vrlo temeljito. Uz to, ako interes bude velik, svaki proizvođač se trudi proširiti ponudu i time krug kupaca. tako bi bilo vrlo realno očekivati neki manji,  vozniji i univerzalniji model sa kakvih 50-70 ks i manjom cijenom. također, ako se mehanika pokaže pouzdanom, mislim da bi iz toga kasnije mogli ispasti i vrlo dobri toureri.
Offline baron0101
  • Postova: 364
« Odgovori #4 : Kolovoz 06, 2007, 14:12:49 pm »
Sorry, da sam znao da vec postoji ne bih otvarao temu
2t u srcu
Offline Đoko
  • Postova: 77
« Odgovori #5 : Kolovoz 06, 2007, 14:27:02 pm »
Stvarno su pretjerali s cijenom!!!Za te novce kupiš novi auto i to malo bolji i motor!!
Vespa 150 T5
« Odgovori #6 : Kolovoz 06, 2007, 14:34:59 pm »
Dobro izgleda , ali ne dovoljno
A i dizel mi nije neka brija
Radje si slozim S&S-a
« Odgovori #7 : Kolovoz 06, 2007, 17:24:48 pm »
Heheheheheheh........ja bi ga vozil i da je na ocat  :icon_mrgreen: :icon_mrgreen:
Offline oorascan
  • Postova: 86
« Odgovori #8 : Kolovoz 06, 2007, 20:52:22 pm »
Promašen slučaj....
No nije baš ružan, ali da je koncept mašine barem V, pa neka je i diesel...
Lp
neodoljivi....
« Odgovori #9 : Kolovoz 06, 2007, 22:23:19 pm »
nije ti loša tema, i nije bila otprije, motor je samo usput spomenut u vezi nečeg drugog. stavio sam citate  najviše radi slike prvog koncepta i usput svoj dojam
« Odgovori #10 : Kolovoz 06, 2007, 22:25:03 pm »
Promašen slučaj....
Lp
Firma je poznata po konstrukcijama diesel-agregata i to im je primarno usmjerenje. Motocikl je samo širenje asortimana. Ako se pokaže da ima tržišta i za V, neboj se, napravili budu i dobar diesel V.
Offline oorascan
  • Postova: 86
« Odgovori #11 : Kolovoz 07, 2007, 22:56:17 pm »
bumo vidjeli...
pozdrav
neodoljivi....
Offline toldi
  • Postova: 903
  • Aprilia Pegaso
    • Vanishing-Points
« Odgovori #12 : Kolovoz 08, 2007, 09:37:15 am »
Nekima nije brija diesel, no ja odgovorno tvrdim da potisak i osjećaj momenta na takvome nečemu bi bio za pamćenje...
Uzmi auto koji ima približne karakteristike pa vuče ko mutav, za razliku od benzinaca kod kojih nema toga... Imam i primjer, u nissanu imam 88 ks benz., a kad sam isti takav probao diesel sa 85 ks mislil sam da mu se budu ramena ščupala, mada priznajem špica je nešto manja kod diesela...
Offline dex123
  • Postova: 1.132
  • vozi- u šumi
« Odgovori #13 : Kolovoz 08, 2007, 11:10:04 am »
to je bio turbodizel zato si imo osječaj,ali to je samo trenutni osjećaj snage zbog momenta i kraćih prjenosnih omjera mjenjaća,nijedan turbodizel nemoze konkurirat benzincu koji je u okretajima a gdi je tek kraj kad na benzinca stavis turbo,
nisam ovim textom mislio nista lose nego eto tek osvrt i nezamjenjivost mirisa benzina  :icon_eek:  :icon_super:
što se tiče cjene ovog motora,nisam vidio lošiju ponudu  nit je brz ,nit je uporaban, i ocito budu onu agresivniju razvojnu verziju kroz neko vrjeme stavili pod evo nov model, i da sam bil gates radje bi si za te pare sam sastavil motor
i mogu si zamislit kad zenski dio publike pita zakaj je zavinut auspuh e pa ak se zbog tog treba dat tolko para.....
nebum vise pisal jel pisem ogorceno ha ha ha
« Odgovori #14 : Kolovoz 08, 2007, 12:39:44 pm »
Das 70.000 eura da bi vozio stedljivo...  :icon_scratch:
Ne izgleda lose, u svakom slucaju tehnicka poslastica.
