Autor Tema: AMC bikes  (Posjeta: 3002 )
AMC bikes
« : Svibanj 01, 2007, 01:06:04 am »
“Ol School” Bobber
AMC1902 “Ol School Bobber”
Engine: S&S 96 c.i. Motor generating 104 hp,
or
RevTec 110 (other engines choices are available)
Compufire Dual Fire Ignition System
Instruments: Vintage style speedo, and horn
Transmission: 6 Speed Polished Transmission
Left Side Drive
3.5” Open Primary
Final Drive is Chain
Frame / Suspension: Rigid frame is from Maxximum Metalworks
Color Match Powder Coat Frame
Custom springer style seat
Warranty: 2 Year Factory Warranty & Optional Extended Plan
Front End: Spring style front suspension w/ 38 Degree Rake,
3” Stretch & 6” Riser
Old School style single disc brakes front and rear
Lighting: Bates
Wheels & Tires: Custom Painted or chrome Wire Wheels – 16 x 3.5 Front Rim
Tires: Metzler 130 x 16
Custom Painted or chrome Wire Wheels – 16 x 3.5 back Rim
Tires: Metzler 150 x 16
Paint & Chrome: Various Custom Paint options are available
Heavy use of Chrome and Polish
Compufire: 32 Amp charging system
Exhaust System: Vintage Style Exhaust by Brute Exhausts (other opt. available)
Handlebars: Apes were furnished by “Chubby’s”
Forward Controls: Vintage Look Forward Controls and floorboards by
Options: Options available: sissy bar & two up seating, chrome billet wheels, various motor choices, show polish motor, diamond cut heads, inverted front end, open or closed primary, custom paint, and more.
Tracker Bobber
« Odgovori #1 : Svibanj 01, 2007, 01:19:21 am »
Tracker Bobber
AMC1902 “Tracker Bobber”
Engine: SS&S 96 c.i. Motor generating 104 hp,
or
Left Side Drive
3.5” Open Primary
Front End: Wide Glide Front End
Lighting: Bates
Wheels & Tires: Custom Painted or chrome Wire Wheels – 21 x 3.5 Front Rim
Tires: Metzler 120 x 21
“Choctaw” 300 Chopper
« Odgovori #2 : Svibanj 01, 2007, 01:22:25 am »
AMC1902 “Choctaw” 300 Chopper
Engine: S&S 111 c.i. Motor generating 114 horsepower
(optional engines are available: please ask for pricing)
Compufire dual fire Ignitions.
Custom Wiring Details: Thunderheart wiring system
Custom Dakota Digital speedo / tach combo
Transmission: 6 speed polished transmission
Right side drive
W/ 3” open primary
Final drive is chain
Frame / Suspension: Softail frame is from Maximum Metalworks
(Available as optional air shock suspension)
Pinstriping: 2 year factory warranty, Optional Extended Plan
Front End: Wide glide ball milled custom inverted front end (Other options available)
40 degree rake, 3” stretch, 6” riser
Chrome billet lower leg’s – 10 over
Chrome triple tree’s
Single disc chrome brakes front and rear w/ four piston caliper’s
Lighting: Signal Dynamics LED’s and signals
RPM headlights and tailight’s
Wheels & Tires: Polished billet wheels – 21 x 3.5 Front Rim
Tires: Avon 120 / 70 x 21 front
Polished billet wheels – 18 x 10.5 back Rim
Tires: Avon 300 / 40 x 18 rear
Paint & Chrome: Custom paint options are available
Color matched powder coat frames
Heavy use of chrome and polish
Compufire: Single Phase – 32 Amp charging system
Exhaust System: Street Walker or Big Growl
Handlebars: T-Bar’s
Odg: AMC bikes
« Odgovori #3 : Svibanj 01, 2007, 07:49:02 am »
 :icon_super: :icon_super: :icon_super: :icon_super: :icon_super:
Odg: AMC bikes
« Odgovori #4 : Svibanj 01, 2007, 14:12:47 pm »
Ova prva dva kao da su na mene mislili kad su ih radili. nebih mijenjao baš ništa na njima. naročito onaj prvi :icon_super:
Odg: AMC bikes
« Odgovori #5 : Svibanj 01, 2007, 16:47:43 pm »
Ja bi, boju felgi! Nego nije mi jasno ćemu služi to omotavanje ispušnih grana odnosno cijevi?  :icon_scratch:
Odg: AMC bikes
« Odgovori #6 : Svibanj 01, 2007, 17:09:18 pm »
danas samo image, takav stil prerade
Odg: AMC bikes
« Odgovori #7 : Svibanj 01, 2007, 17:22:21 pm »
Znam da će ova izjava s obzirom na kontekst i vrstu motora zvućati malo blesavo, ali tko to može očisti od mušica, blata, katrana i sl.? Svaka druga vožnji dole sa tim, a gore sa novim. Ovo nisu show bike motori tako da ipak treba imati na umu kako će se to voziti i po cesti.  :glasses9:
Offline Rude
  • Postova: 112
  • Kymco Venox 250
Odg: AMC bikes
« Odgovori #8 : Svibanj 03, 2007, 18:50:12 pm »
julius; uvijek se mozes predati pred ciscenjem i napraviti jedan dobar rat-bike od toga :))))))
kako se zovu muhe u sloveniji?? ne zovu se, one same dojdu :)))
Odg: AMC bikes
« Odgovori #9 : Svibanj 03, 2007, 19:25:46 pm »
Malo $$$ za kemiju i ne treba ti ni cijeli dan za oprat :icon_mrgreen:
 Otprilike tako :icon_confused:
