Autor Tema: 2007 Midnight Warrior  (Posjeta: 2004 )
« : Travanj 25, 2007, 21:04:22 pm »
Engine
Type 102 cubic-inch (1670cc), pushrod OHV, air-cooled, 48-degree V-twin, 4-valve per cyclinder
Bore x Stroke 97mm x 113mm
Compression Ratio 8.3:1
Ignition Digital TCI
Final Drive Belt
Transmission 5-speed, close-ratio, w/multi-plate wet clutch
Fuel Delivery Twin-bore Fuel Injection, w/throttle position sensor
Chassis
Suspension/Front 41mm Kayaba inverted telescopic fork, 5.3" travel
Suspension/Rear Single shock, link-type w/adjustable preload and rebound damping; 4.3" travel
Brakes/Front Dual 298mm Discs
Brakes/Rear 282mm Disc
Tires/Front 120/70-ZR18 Radial
Tires/Rear 200/50-ZR17 Radial
Dimensions
Length 93.9"
Width 36.8"
Height 44.1"
Seat Height 28.7"
Ground Clearance 6.1"
Wheelbase 65.6"
Dry Weight 613 lb.
Fuel Capacity 4 gal.
meni najdrazi motor tog tipa
Offline rockydennis
  • Zamagljeni
  • Savjesno i odgovorno
Odg: 2007 Midnight Warrior
« Odgovori #1 : Travanj 26, 2007, 01:01:58 am »
Posebno mi se sviđa kaj nema onu kantu of fara! Auspuh bi mogao biti i malo manji ili još bolje dvostruki...
www.cro-chopper.forum-2007.com
Volim burek, zeljanicu pitu,
volim cure što ne pamte Titu!
« Odgovori #2 : Travanj 26, 2007, 03:02:47 am »
Začudo,ima i takav :icon_mrgreen: :icon_mrgreen:.Jedino kaj ima mala sitnica,sitan problemčić......tank od 4 gal.Ugrubo oko 15L ak je u igri US gal,i 18L ak je Imperial gal.Zanima me koliko troši ta mašina od 1700 ccm na 100 km?Da je motor preheben,je.Da bi ga htel imati,je. :icon_mrgreen: :icon_mrgreen:
Offline catevs
  • Bjelovar
« Odgovori #3 : Travanj 26, 2007, 07:40:50 am »
Jedan od rjetkih koji se i meni sviđa
Znam da alkohol škodi, al u vodi utjehe nema!
Offline paperinos
  • Postova: 53
« Odgovori #4 : Travanj 27, 2007, 00:42:04 am »
To vise i nisu kruzeri.
Definicija pravog kruzera je XV 1600 vild star ili 1100 drag star.
« Odgovori #5 : Travanj 28, 2007, 16:01:59 pm »
"muscle bike"
Offline Rude
  • Postova: 112
  • Kymco Venox 250
« Odgovori #6 : Svibanj 03, 2007, 18:53:38 pm »
jedino kaj bi mjenjo na njemu su felge. svavio bi zicane,  a ne ovakve. ko da se nisu trudili oko toga. kak na vn900 ljepo izgledaju iako su alu. bokte na venoxu su ljepse
kako se zovu muhe u sloveniji?? ne zovu se, one same dojdu :)))
« Odgovori #7 : Svibanj 03, 2007, 21:54:40 pm »
Offline paperinos
  • Postova: 53
« Odgovori #8 : Svibanj 05, 2007, 01:08:00 am »
Novotarije i trend za par sezona.
Klasika je vecna, nema greske u izboru tradicionalnog dizajna.
Sve ovo su samo lutanja koja ce posle par sezona biti smesna.
Offline rockydennis
  • Zamagljeni
« Odgovori #9 : Svibanj 05, 2007, 16:20:44 pm »
Skoro pa tako... problem je da oni (i sva konkurencija) žele napraviti serijski custom a to se stručno kod jezikoslovaca zove oksimoron (kad spojiš dvije nespojive riječi u jedan izraz, npr. nevina mađarica :llllol: :icon_super:)
Offline paperinos
  • Postova: 53
« Odgovori #10 : Svibanj 06, 2007, 20:25:14 pm »
Hehehehe  dao si definiciju pomodarstva kod proizvodjaca.
Prodaju nam svake godine nesto novo i skuplje a nekvalitetnije.
