Autor Tema: 2006 Warrior Star  (Posjeta: 2474 )
2006 Warrior Star
« : Listopad 12, 2005, 23:09:59 pm »
$12,399 (Candy Red) Available from September 2005
$12,499 (Cobalt Blue w/Star Silver Flames) Available from September 2005
$12,699 Midnight Warrior (Onyx) Available from September 2005
Engine
Type   102 cubic-inch (1670cc), pushrod OHV, air-cooled, 48° V-twin
Bore x Stroke   97mm x 113mm
Compression Ratio   8.3:1
Ignition   Digital TCI
Transmission   5-speed, close-ratio, w/multi-plate wet clutch
Final Drive   Belt
Fuel Delivery   Twin-bore Electronic Fuel Injection, w/throttle position sensor
Chassis
Suspension/Front   41mm Kayaba inverted telescopic fork, 5.3" travel
Suspension/Rear   Single shock, link-type w/adjustable preload and rebound damping; 4.3' travel
Brakes/Front   Dual 298mm Discs
Brakes/Rear   282mm Disc
Tires/Front   120/70-ZR18 Radial
Tires/Rear   200/50-ZR17 Radial
Dimensions
Length   93.9"
Width   36.8"
Height   43.9"
Seat Height   28.1"
Ground Clearance   6.1"
Wheelbase   65.6"
Dry Weight   606 Lbs.
Fuel Capacity   4 Gallons
Other
Warranty   1 Year (Limited Factory Warranty)
2006 Warrior Star
« Odgovori #1 : Listopad 12, 2005, 23:10:53 pm »
Ovaj motor mi je oduvijek bio lijep, slinim i gledam...
2006 Warrior Star
« Odgovori #2 : Listopad 13, 2005, 12:51:02 pm »
Bee ovaj put se definitivno slažem s tobom!  :thumbup:
Meni je također to jedan od najljepših motora! Baš sam neki dan bio s Dodom kod Markeza i gore je bio Warrior od MotoVito-a. Ntko ga je malo"česnul" pa ga je trebalo popravit. U živo izgleda stvarno impresivno, močno... Ma..
2006 Warrior Star
« Odgovori #3 : Listopad 15, 2005, 09:54:47 am »
Ima više smisla od MT-a. Kad iamš 1700ccm,nek je mrcina i nek se to vidi.
2006 Warrior Star
« Odgovori #4 : Listopad 16, 2005, 01:19:33 am »
Citat: "james1100"
Slazem se, ali ovo je potpuno drugi koncept i ima smisla za razliku od MT-a
Offline brum
  • Road King
  • Postova: 1.520
2006 Warrior Star
« Odgovori #5 : Studeni 30, 2005, 23:16:02 pm »
Da, za razliku od MT koji izgleda kao hrpa agregata zguranih u kut, ovaj motor je svakako ljepotan. Duuuuugačak, nizak, s ogromnim topom. Da mi je čuti zvuk, uh!
ruuuuum, bruuuum, bruuuum...!!!
2006 Warrior Star
« Odgovori #6 : Prosinac 01, 2005, 00:02:58 am »
ogromni top ne znaci glasan zvuk , obicno je obrnuto
2006 Warrior Star
« Odgovori #7 : Prosinac 02, 2005, 21:31:32 pm »
Mali pimpek veliki jebach; veliki pimpek mali jebach?  :?:   :scratch:
Mislim da bi tu i cure imale nekaj za komentirat!  :mrgreen:
2006 Warrior Star
« Odgovori #8 : Prosinac 03, 2005, 01:01:25 am »
Citat: "Julius"
ti se to tjesis :mrgreen:
2006 Warrior Star
« Odgovori #9 : Prosinac 03, 2005, 06:14:09 am »
Citat: "Beeblebrox"
Citat: "Julius"
Odgovorno tvrdim da ovo s Velikim nije istina!  :x
Offline Rene(Raptor)
  • Postova: 129
    • http://www.reneko.hr
2006 Warrior Star
« Odgovori #10 : Prosinac 03, 2005, 14:07:05 pm »
je, jedan od ljepših serijskih choppera japanskih tvornica...
ova usporedba s MT-om ne stoji u potpunosti - to su 2 različita svijeta
MT mi je (moram otvoreno reć) bio preedobar motor dok ga nisam vidio u živo, a onda razočarenje, ono stop svjetlo izgleda kao da sam ja amater isfrustriran time što nemam stop svjetlo najnovije LED tehnologije, otišao u chipoteku i kupio (doslovce) neki "štap" ili rasvjetno tijelo na kojem se nalaze LED-ice...
ispod suvozačkog sica nitko vjerojatno nije primjetio VENTILATOR?! znate čemu to služi? zato da bi se pratili najmoderniji trendovi u svijetu motocikala yamaha je mt-u stavila 2 auspuha ispod sica (ma vrhunska ideja :x , imaš agregat od 1670ccm i očekuješ da će auspusi koje bubneš ispod sica biti hladni), a pri tome je tek naknadno razmislila o količini topline koju suvozač prima ispod guzice! tako da taj ventilator ima samo ulogu hlađenja guzice suvozaču - po mojem to je veliki konstrukcijski propust (jerbo to je samo prosipanje energije motocikla i poskupljivanje proizvodnje, otežavanje servisiranja - dajte si zamislite koliko dodje taj ventilator koji je rađen vrlo vjerojatno u ograničenoj seriji i to samo za MT-01 jer nijedna druga yamaha ga nema)...
za warriora ne znam jer motor mi se na prvi pogled čini preopako, vidio ga kod markeza prošle (ili je to bilo pretprošle) godine...
ww.reneko.hr
