Autor Tema: Yamaha 2007 Royal Star Venture  (Posjeta: 3593 )
« : Kolovoz 02, 2006, 10:58:05 am »
MSRP*   $17,099 (Galaxy Blue/Raven) Available from July 2006
$17,399 Midnight Venture (Raven) Available from July 2006
Engine
Type   79-cubic-inch (1294cc) liquid-cooled, DOHC, 70-degree V-4
Bore x Stroke   79mm x 66mm
Compression Ratio   10:1
Carburetion   (4) 32mm Mikuni CV
Ignition   Digital TCI
Transmission   Wide-ratio 5-speed w/5th gear overdrive and hydraulic clutch
Final Drive   Shaft
Chassis
Suspension/Front   Telescopic fork w/air assist; 5.5" travel
Suspension/Rear   Single shock, link-type w/air assist; 4.1" travel
Brakes/Front   Dual 298mm Discs
Brakes/Rear   320mm Disc
Tires/Front   150/80-16
Tires/Rear   150/90-15
Dimensions
Length   104.5"
Width   35.4"
Height   61.6"
Seat Height   29.5"
Wheelbase   67.1"
Dry Weight   807 lb.
Fuel Capacity   6.0 gal.
Other
Warranty   5 Year (Limited Factory Warranty)
Ima jedan stari u HR (crveni)
Meni je motor prekrasan  :mrgreen:
Ovo je vise kopija  electre UGC nego na winga
Offline Direktor
  • Postova: 853
« Odgovori #1 : Kolovoz 02, 2006, 11:11:44 am »
Motor je prekrasan, al to je negdje oko 19.000€. Malo skupo!
Street Illegal
Offline virago11
  • Postova: 183
  • BMW R1200C
« Odgovori #2 : Kolovoz 02, 2006, 12:56:29 pm »
Uuuu jebote možda jednog dana.......
odoh uplatit loto  :x
Offline bLind faiTh
  • Postova: 32
« Odgovori #3 : Kolovoz 02, 2006, 16:50:21 pm »
ma...di je to do honde gold wing....
« Odgovori #4 : Kolovoz 02, 2006, 17:07:29 pm »
Citat: "bLind faiTh"
po cijeni ni blizu  :mrgreen:
Offline choke
  • Postova: 256
« Odgovori #5 : Kolovoz 02, 2006, 18:29:56 pm »
Ja sam vidio par komada-ima ih nekoliko u sloveniji-mislim da u ovom slučaju honda nije ni do koljena yamahi
amahahahhahahahaaaaaaaa
4rijeke
« Odgovori #6 : Kolovoz 02, 2006, 19:33:52 pm »
patite se smrtnici :)
BMW's profilation of this bike
The freedom to discover the world. On the BMW R 1200 CL, alone or with a partner, cruising luxuriously - sometimes over long distances. The BMW R 1200 CL combines the laid-back character of a Cruiser with a fascinating level of travel comfort.
General information
Model: BMW R 1200 CL
Year: 2005
Category: Custom / cruiser
Rating: 73.1 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 1170.00 ccm (71.39 cubic inches)
Engine type: Two cylinder boxer
Stroke: 4
Power: 60.34 HP (44.0 kW)) @ 5000 RPM
Torque: 98.00 Nm (10.0 kgf-m or 72.3 ft.lbs) @ 3000 RPM
Compression: 10.0:1
Bore x stroke: 101.0 x 73.0 mm (4.0 x 2.9 inches)
Fuel system: Injection. Electronic intake pipe injection/digital engine management: Bosch Motronic MA 2.4 with overrun fuel cut-off, twin spark ignition
Valves per cylinder: 4
Fuel control: SOHC
Cooling system: Oil & air
Gearbox: 6-speed
Transmission type
final drive: Shaft drive (cardan)
Clutch: Single-disc dry clutch, hydraulically operated
More details Consult a BMW repair manual.
Physical measures
Dry weight: 288.0 kg (634.9 pounds)
Weight incl. oil, gas, etc: 308.0 kg (679.0 pounds)
Seat height: 745 mm (29.3 inches) If adjustable, lowest setting.
Overall height: 1,435 mm (56.5 inches)
Overall length: 2,415 mm (95.1 inches)
Overall width: 1,075 mm (42.3 inches)
Wheelbase: 1,641 mm (64.6 inches)
Chassis and dimensions
Frame type: Three-section composite frame consisting of front and rear section, load bearing engine.
Rake (fork angle): 33.5°
Trail: 184 mm (7.2 inches)
Front suspension: BMW Motorrad Telelever
Front suspension travel: 35 mm (1.4 inches)
Rear suspension: Die-cast steel single-sided swinging arm with BMW Motorrad Monolever
Rear suspension travel: 135 mm (5.3 inches)
Front tyre dimensions: 150/80-VR16
Rear tyre dimensions: 170/80-VR15
Front brakes: Double disc
Front brakes diameter: 305 mm (12.0 inches)
Rear brakes: Single disc
Rear brakes diameter: 285 mm (11.2 inches)
Speed and acceleration
Top speed: 165.0 km/h (102.5 mph)
Power/weight ratio: 0.2095 HP/kg
Other specifications
Fuel capacity: 17.50 litres (4.62 gallons)
Fuel consumption pr. 10 km (6.2 miles): 5.10 litres (1.35 gallons)
Comments: ABS brakes.
Further information
Parts and accessories Check out parts and accessories from our partners.
Ask questions Join the 05 BMW R 1200 CL discussion group
Insurance, loans, tests  Search the web for dealers, loan and insurance costs, tests, customizing, etc
« Odgovori #7 : Kolovoz 02, 2006, 20:26:46 pm »
meni je ruzan vidio sam ga uzivo
Offline oldbiker
  • Umag
  • V.I.P. Member
  • Postova: 1.117
  • Honda CBR1100XX
« Odgovori #8 : Kolovoz 02, 2006, 22:13:26 pm »
Kakve su to krstarice ! Još sigurno 15 godina ne razmišljam o tim kamionima !  :supz:
Motor vozi glavom ali malo i srcem. Free biker - bolje biti sam, nego u lošem društvu !
Medic
« Odgovori #9 : Kolovoz 03, 2006, 07:47:05 am »
Citat: "Beeblebrox"
Meni također, a i 60 ks na 300 kg suhe težine.......s tim nema preticanja, eventualno traktori :mrgreen:
Offline Dodo1
  • Postova: 267
« Odgovori #10 : Kolovoz 03, 2006, 07:50:21 am »
Sve su to samo lepe nefunkcionalne krave! isto ti je imao to ili auto a ako oces da ti puse uzes kabrio !!!  glasam za auto !!!  :mrgreen:
Offline Deathmaster
  • Postova: 378
    • Kliknite za Hrvatsku
« Odgovori #11 : Kolovoz 03, 2006, 23:44:56 pm »
a kad pogledaš kolko košta smrzneš se i onda pingvini padaju oko tebe kolko si hladan
If you can't beat them, join them!
Da sam normalan poludio bi :) ! ! !
« Odgovori #12 : Kolovoz 05, 2006, 23:17:55 pm »
Citat: "Medic"
Citat: "Beeblebrox"
Imam Escort karavan 75ks i pretičem normalno. A sigurno je teži od tog motora. Da sad ne nabrajam razne Intrudere,Harleye i slično koje ljudi normalno voze.
« Odgovori #13 : Kolovoz 05, 2006, 23:20:24 pm »
Citat: "Beeblebrox"
Ružan je,ali vrlo učinkovit i dobar za to kaj je napravljen. I dobro se ponaša,bolje nego bi čovjek očekivao. Ja ga vidio "u akciji" u gužvi na autoputu.
« Odgovori #14 : Kolovoz 05, 2006, 23:20:59 pm »
Citat: "oldbiker"
Klinac :mrgreen:  :mrgreen:
