Autor Tema: Boss Hoss 2006  (Posjeta: 17645 )
Boss Hoss 2006
« : Ožujak 22, 2006, 10:57:39 am »
BHC-3 502
General information
Model:   Boss Hoss BHC-3 502
Year:   2006
Category:   Custom / cruiser
Engine and transmission
Displacement:   8200.00 ccm (500.36 cubic inches)
Engine type:   V8
Stroke:   4
Power:   502.00 HP (366.4 kW))
Torque:   567.00 Nm (57.8 kgf-m or 418.2 ft.lbs)
Compression:   9.6:1
Fuel system:   Carburettor. Quadrajet 850 cfm
Starter:   Electric
Cooling system:   Liquid
Transmission type
final drive:   Belt
Physical measures
Dry weight:   589.7 kg (1,300.0 pounds)
Seat height:   724 mm (28.5 inches) If adjustable, lowest setting.
Wheelbase:   2,083 mm (82.0 inches)
Chassis and dimensions
Front brakes:   Double disc
Rear brakes:   Single disc
Speed and acceleration
Power/weight ratio:   0.8513 HP/kg
Other specifications
Fuel capacity:   32.17 litres (8.50 gallons)
___________________________________________________________________________
BHC-3 ZZ4
General information
Model:   Boss Hoss BHC-3 ZZ4
Year:   2006
Displacement:   5700.00 ccm (347.81 cubic inches)
Engine type:   V8
Stroke:   4
Power:   355.00 HP (259.1 kW))
Torque:   405.00 Nm (41.3 kgf-m or 298.7 ft.lbs)
Starter:   Electric
Transmission type
final drive:   Belt
Physical measures
Dry weight:   499.0 kg (1,100.0 pounds)
Seat height:   711 mm (28.0 inches) If adjustable, lowest setting.
Wheelbase:   2,032 mm (80.0 inches)
Power/weight ratio:   0.7115 HP/kg
Offline choke
  • Postova: 256
Boss Hoss 2006
« Odgovori #1 : Ožujak 22, 2006, 17:53:43 pm »
a cijena ?? :mrgreen:
amahahahhahahahaaaaaaaa
Boss Hoss 2006
« Odgovori #2 : Ožujak 22, 2006, 17:54:26 pm »
Citat: "čoke"
mislis ulja  :mrgreen:
Offline Direktor
  • Postova: 853
Boss Hoss
« Odgovori #3 : Rujan 14, 2006, 17:23:33 pm »
Evo slika od teške mašine. Prije sam čitao o liku koji je napravio Boss Hoss sa nekih 500ks + nitro. Bojim se da ni ovo nije daleko od toga...
Street Illegal
Offline Zoltan
  • Postova: 434
Boss Hoss
« Odgovori #4 : Rujan 14, 2006, 18:23:26 pm »
ebate... izgledaju kaj putujući kredenci :glasses7:
Hiroshima 45'  Černobil 86' Windows 95'
imacu i ja pravi motor
Boss Hoss
« Odgovori #5 : Rujan 14, 2006, 21:08:56 pm »
Dva točka i motor Ševrolet Korvete?
Spoj automobila i motocikla?
Tipično američko preterivanje u stilu: ,,veličina jeste bitna''?
Sve to je Boss Hoss.
Dobar za planinske puteve pune serpentina :mrgreen:
Boss Hoss
« Odgovori #6 : Rujan 14, 2006, 22:05:22 pm »
Bilo već.
http://www.motocikli.com/forum/viewtopic.php?t=1192&highlight=boss+hoss
Ima i na galeriji što smo slikali u Padovi.
vn 900
Daytona Boss Hoss Custom V8
« Odgovori #7 : Studeni 26, 2006, 20:33:54 pm »
Debelo,veliko,široko,bučno,zeleno
Offline Charlie
  • Split-Dalmacija
  • Postova: 916
  • BMW R80 RT
Odg: Daytona Boss Hoss Custom V8
« Odgovori #8 : Studeni 26, 2006, 20:41:03 pm »
Ovaj motor isključuje mogučnost da vlasnik ostane neprimjećen :dontknow:
« Odgovori #9 : Studeni 26, 2006, 23:46:55 pm »
...ovakve kombinacije boja mi se vise dopadaju..
vn 900
« Odgovori #10 : Studeni 27, 2006, 09:50:42 am »
Ovaj zeleni me podsjeća na traktor đondir, mislim da je i znak sastrane (jelen) njegov.
« Odgovori #11 : Studeni 27, 2006, 22:56:51 pm »
Točno. Jelen i boje su John Deere.
Offline custom fanatic
  • Postova: 34
« Odgovori #12 : Prosinac 01, 2006, 00:56:08 am »
al je V8  :icon_mrgreen:
LCOHOL - The Cause Of - And Solutin To  - All Of Life's Problems
Offline Simon
  • Samobor
  • Postova: 322
  • CB 400N / GSX 550EF
« Odgovori #13 : Prosinac 01, 2006, 09:45:45 am »
Mrak mi je taj John Deer ocu reci Boss Hoss.. nisam to nikad uzivo vidjela sam na slikama  :icon_sad:
M.K. KOMPA
http://www.mk-kompa.com/
You have the right to remain silent.
anything you say will be misquoted,
and used against you..
Prevodim s njemačkog, pa ako neko treba..
« Odgovori #14 : Prosinac 01, 2006, 22:22:31 pm »
Zeleni djeluje više odbojno nego privlačno,više kao kućna radinost negoli kao ozbiljna prerada.
Uz određene preinake barem će biti koristi od njega u polju :icon_mrgreen:.
Ali model što ga je FZ1 postirao je sasvim druga priča :icon_thumright:.
